Old 08-10-2016, 09:29 PM
yamachuck yamachuck is offline
Default New 149
hello everyone ,I just picked up this 149 looks all original for the most part, run s very well ,no smoke hydraulic lift .my first wide frame build.i had to adjust the front pto clutch because it was stuck in engage ..thats what the guy I bought it from said,,ha..,2 min later at home .clutch works .we will see when I put a load on it..i may cut grass till winter then refurbish.
Old 08-10-2016, 09:31 PM
Default more pics
here are more pics .check out the home made hitch..
Old 08-10-2016, 10:46 PM
Congrats on the 149!
Old 08-10-2016, 10:53 PM
Terry C's Avatar
Terry C Terry C is offline
Congrats on the 149. Your tread plates are gone so be careful when stepping on with wet shoes!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 08-10-2016, 11:42 PM
Get yourself the original and install it where it should be, down low.
Old 08-11-2016, 07:34 AM
Tom4981's Avatar
Tom4981 Tom4981 is offline
Congratulations....that's a nice looking 149
Old 08-11-2016, 08:48 AM
Old 08-11-2016, 12:03 PM
SGragg SGragg is offline
Inactive Member
Congratulations on the new-to-you 149!
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 08-15-2016, 08:00 PM
WELL THE 149 I BOUGHT WAS REALLY TAKEN CARE OF NO SMOKE FROM THE MOTOR .I PUT NEW POINTS ,CONDENSOR .PLUG.AIR FILTER.THIS THING PURRS..CHANGE THE HYDRO FILTER AND HYTRAN,AND YES THERE WAS A LITTLE JELLY HA..INEED TO ADJUST THE HYDRO WHEN YOU STEP ON THE BRAKE IT GOES FORWARD..AS FOR THE MOWING DECK ALL THE BEARINGS ARE PERFECT,AND BLADES ARE PERFECT ALSO I AM AMAZED..ORDERED 2 NEW BELTS FOR THE DECK AND THE DRIVE..THIS DECK IS IN BETTER CONDITION THAN MY 09 CUB..THERE MUST HAVE BEEN BETTER STEEL BACK THEN..I GOT LUCKY WITH THIS ONE
Old 08-15-2016, 08:12 PM
Why are you yelling?
Pap's 100
Restored 108
1211 Dual Stick
1050
