Old 08-27-2016, 06:42 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Default An easier oil change
I always thought it was a PIA to change the oil on the Cub Cadet.....especially with the mower deck installed. Either take the deck off or find a way of channeling waste oil into pan without making a big mess (usually ends up in a mess, anyway). Just a PIA either way! Until I found this scoop for cleaning leaves out of gutters. I just stick it under drain plug over mule drive frame. The oil pour out the front of tractor under the grill. No mess.
Plow blade
#2 Cart
QA36 snowthower
Old 08-27-2016, 06:49 PM
Great idea, Billy!
Old 08-27-2016, 07:32 PM
twoton twoton is offline
Nice! Was thinking the same thing, now I just have to getta gutter getter
Old 08-27-2016, 07:46 PM
I had the sheetmetal guy bend up a piece for me and I welded an end on it.
Works fine
If you have enough tilt ( angle ), a regular piece of rain gutter would work too.
Old 08-27-2016, 07:51 PM
I'm old and cheap, I just use some bent card board.
Old 08-27-2016, 08:01 PM
I'm old and frugal, I just use some bent card board.
FTFY
You're not cheap Sam, just frugal. You will spend funds when needed but also save when you can.
Cheap never spends money at all.
Old 08-27-2016, 08:53 PM
Nice work Mr. Billy but where do the leaves end up?
I use a plastic detergent container,cut off the side and stick it between the mule drive frame.
Up to 534 and counting...
Old 08-27-2016, 09:05 PM
Billy-O's Avatar
I'm not any more concerned about where the leaves end up than what detergent oil you use to wash your clothes!
Plow blade
#2 Cart
QA36 snowthower
Old 08-27-2016, 10:18 PM
This is a very useful thread! Thanks for posting. I have used a flexible funnel before, which worked very nicely at first until the drain plug slipped out of my fingers and into the funnel, which then overflowed and you know the rest.....So while others have great ideas to share here, my comment is what NOT to do.
Great ideas those on re-purposing other things!
Old 08-28-2016, 07:33 AM
john hall's Avatar
Never tried to drain oil with "paper" (I bet waxy cardboard would work great!) but we used to have a farm tractor with saddle tanks on the sides (100 gal).It used 1 qt of oil per day. In the field we would rip a section out of a soybean seed bag and roll it into a funnel, about the size of an oversize waffle cone so we could pour in the oil---from a can we punctured with a screwdriver and hammer---Dang I'm getting old, I haven't seen cans of oil for sale in close to 30 years
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
