Old 09-22-2016, 09:11 AM
Tament Tament is offline
Default Picked this up recently
New to the Forum, picked up this 1554 recently, the problem with it is that after cutting for about 20 mins or so the PTO cuts out. Let it cool down and it will run again. I did a OHM and voltage check on the tractor side of the PTO wire and i get 14v, and I think the ohms was 2. something, cant remember exactly. I am thinking the PTO is bad, but I am going to try and change the PTO switch before doing the PTO. I did try testing the resistance on the PTO, but I may not be doing the check right, as I am not getting back any reading stays at 0.00.
I have the multimeter set to ohms 20m or 20k, touch contacts and nothing. The battery does have a good charge and at full throttle with PTO engaged, I am getting 14v.
I need to test the switch when the failure is happening, so I will try to do that and report back
Old 09-22-2016, 10:29 AM
Welcome to the forum!
The GT1554 is considered a garden tractor. I moved this thread to the proper section.
You could have a failing PTO, but a wiring issue is more likely the case on a tractor of that vintage. Continue and test to see that you have power getting to the PTO when it quits.
Old 09-22-2016, 06:00 PM
Welcome to OCC! Congrats on the GT1554!
