Old 09-28-2016, 01:56 PM
Tom4981's Avatar
Tom4981 Tom4981 is offline
Default Carlisle tru power lug
I'm looking at getting a set of these for the Cub 102....these are 4 ply tires. size would be 23x10.50-12
I already have a Johnny Bucket and plan on getting a snow blower attachment..The photo is what they look like.....Opinions please..
Old 09-28-2016, 02:19 PM
I have them on two of my tractors and there great.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 09-28-2016, 02:25 PM
twoton twoton is offline
I recently picked up a set for a tiller project, they look very cool. I think I would prefer turfs with chains for my blower but some guys have good luck just loading the ags.
Old 09-28-2016, 04:35 PM
Great tire. I get mine here for $100 shipped to your door.
https://www.stopandgotires.com/tire/...%20Tru%20Power
Old 09-28-2016, 04:41 PM
Tom4981's Avatar
Thats the cheapest Ive seen them yet....Thanks for the link I bookmarket it.
Old 09-29-2016, 12:04 AM
As Tim said, they are great.
And seems Todd (Oak) has been holding out his tire contact.
Old 09-29-2016, 07:09 AM
drcjv's Avatar
drcjv drcjv is offline
I have supers with both set ups, ags as well as turfs with chains. I have found that when plowing snow as well as pulling a dirt plow the turfs with chains. have out performed the ags every time. Both set ups also have filled tires and wheel weights. I think the ags look cool but I have had better experience with the turfs and chains. Especially when plowing dirt.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 09-29-2016, 08:58 AM
I have tested the same set up you just described with the opposite results. I wonder how they could be so opposite? I'd be interested to know what AG tires you were using, how much pressure was in the tires, type of dirt..... because I have ran equipment for a long time, and what your saying just doesn't really make any sense unless either you had a junk set of tires, or did something wrong such as run incorrect pressures or not use proper weighting. Plus the fact that most everyone says the opposite. Sure, turfs and chains will pull. But not like an AG properly inflated with the proper weighting.
Ags self cleaned in dirt, where turfs and chains got dirt packed up on them and became useless. (Obviously in damp soil.) In dry soil turfs and chains would pull, but I got tired of the noise of chains and the rough ride.
On snow and ice, I had better luck gaining traction with loaded lugs with chains than I ever did while I had turfs on. I think it was because the chain would hit the ice on just the lug. With less surface area, more weight was in a small spot on the tire and it would really bite. With turfs on, (chains and weights) I still got a lot of slip. I used to recommend turfs and chains in the winter, AGs for everything else, but since have had such good luck with AGS and chains that I don't even want a set of turf tires anymore.
Oh, one more thing.... load them with ballast of your choice. The added weight doesn't hurt in grass, and makes a huge difference with used in conjunction with weights when needed.
Old 09-29-2016, 11:34 AM
drcjv's Avatar
Here we go again. The ags are brand new, they are inflated and weighted properly. I probably don't have as many years experience as you I have only been doing this stuff for 43 years. This has been discussed multiple times on the forum and I am not the only one with these results. My guess is that the dirt and snow in PA is different than the snow and dirt in Illinos.
2072 50" deck
Old 09-29-2016, 12:07 PM
The True Powers are good tires. I really like the ones on 121! They should serve you well.
