Old 10-01-2016, 10:16 PM
HydroCub149's Avatar
HydroCub149 HydroCub149 is offline
Default Snow Plow Question. HELP!
I have a snowplow that fit on my grandpas 125 cub cadet and I am trying to put it onto my 1811 can I do it because it seems that the frame is wider than the plow blade and the pins wont line up into the spring loaded thing that holds on the mule drive in the front. Please help me.
Cub Cadet 149 w/ sleeve hitch, rototiller, snowblade and deck, Cub Cadet 124 w/ sleeve hitch and deck Cub Cadet 1811 w/ deck and 18 big internationals 🇺🇸 🔧🐂
Brinley PP-100 plow
Cyclone Rake
Old 10-01-2016, 10:19 PM
No, the 125 is a narrow frame and the 1811 is a wide frame. You will need a different subframe.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-01-2016, 10:26 PM
Thanks Where would I get one at I would like to use it this winter to plow snow and to push cow feed around.
Brinley PP-100 plow
Cyclone Rake
Old 10-01-2016, 10:50 PM
Craigslist is probably the best place, where in pa are you located?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-02-2016, 01:23 AM
Check the sponsors at the top of each page, should be able to find one. Or put a wanted in the for sale section of the forum.
Old 10-02-2016, 08:15 AM
bugeye bugeye is offline
check ebay. Weaverscubcadets probably has some in his barn.
Old 10-02-2016, 04:37 PM
johncub7172's Avatar
I would not confuse "wide frame", meaning the actual Wide Frame Series, and Quiet Line Series with the model 1811. Seems to me, the 1811 has a wider frame than a wide frame model. Some call it a "spread frame" ?
Just saying,........
Old 10-02-2016, 04:43 PM
1811 has the same width frame as the "wide frame". It is just spread at the base of the engine to allow a twin cylinder to go into it. Same attachments fit a "spread frame" as a "wide frame".
Old 10-02-2016, 04:48 PM
Thanks J-Mech, and Olds! I assumed the model 1811 was similar to my previous model 1211, which has the spread frame.
Old 10-02-2016, 04:49 PM
Yep. 1211 and 1811 use the same frame, different motors.
