Well, very soon we , or most of us anyway, will be in our shops with the stove or furnace going and be working on a project to keep busy this winter. So, the question is---- what have you got planned for a winter project(s)? I'll be finishing the paint work on the 782D and installing the turbo kit. What have you got planned?
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
I'd settle for getting my garage where I can actually DO a project in it.... and a furnace.... maybe some more lights/electric, insulation.....
1932 ford coupe and fixing any thing that breaks on my 149 while in the snow.
Start restoring my 982, two cyclops rear braces and drill drain holes.
Rebuild (2) 12hp and one 10.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
You asked so here goes:
Farmall Super A--front transmission seal IH 454--steering cylinder leaking and a bad hydraulic leak on something on the transmission cover top--may have to pull fenders and fuel tank (it has saddle tanks, kind of) 1811--clean hydro out, rebuild carb and 50" deck 782--see what it needs (just bought it) and put a deck from a burnt 1810 under it. New Holland 276 baler--pickup attachment is slipping too easily, replace bushings in overrunning clutch, sharpen/adjust knife Deere 4020---fix the fuel gauge 75 F-350--fix the fuel gauge Early 90's Club Car golf cart---do a cheap rebuild on the engine--smokes like a diesel! 682--replace blown kt17 with a magnum from burnt 1810 (if it survived the fire) 124--level the deck 122--clean out the fuel system and stop leaks farm shop--install those LED lights I bought 2 years ago Farmall Super A (another one)--resolve battery/starter issues Deere haywagon--make a new tailgate to fix the one I destroyed (don't ask) and fix broken floor boards I'm sure there is more, but I'll never get all of this done.
Jon that sounds like me...I have to go outside to change my mind!!!!
"We don’t stop playing because we grow old, we grow old because we stop playing." ![]() |
Lord you can't take me today, way too much to do!!
I plan on resting up and hopefully enjoy snow removal and snow storms, I know it sounds crazy but I worked my butt off this summer
My pre-winter project was getting the grass seed heads knocked down,,,
that happened Wednesday,,, now I have to decide whether to cover the mower for the winter,,, or,, just leave it set uncovered for the winter?? ![]() ![]() At some point this winter, I hope to get the second cutting edge installed in my DIY landplane. The landplane works great with one blade,,, hopefully a second blade will make it even better. ![]() Winter and welding just seem to go together!! ![]() |
I'll be working on my 1985 Dodge Charger or my diesel 100 project
Original, 100 with fenders creeper lights 3pt spring asst., 147 with electric lift IH hubcaps, 102, 126, 682 QA36 snow blower, 2 Dozer blades, Haban sickle bar, John Deere 60 Lawn tractor with deck and snow plow, 1962 Fordson super major backhoe, 1941 Allis Chalmers WC |
