Old 11-14-2016, 10:37 AM
Default Removing Rusted Nuts With a Candle
Have not tried this but thought I'd pass it along. We never have rusty nuts on Cubs.
http://www.chonday.com/Videos/rusnutcankj4
Old 11-14-2016, 12:29 PM
Tom4981's Avatar
Tom4981 Tom4981 is offline
Thats a great tip...thanks for sharing.
Old 11-14-2016, 12:41 PM
PaulS's Avatar
PaulS PaulS is offline
I am definitely going to try this. Sure hope it works especially on steering wheel nuts.
Old 11-14-2016, 01:48 PM
I've done it quite a few times and learned it from a machinist friend years ago, It's worked more times than not.
Old 11-14-2016, 04:06 PM
Looks like a good idea!
Old 11-14-2016, 06:39 PM
ccguy's Avatar
ccguy ccguy is offline
WOW! Thanks for sharing such a great trick Sam!
INTERNATIONAL HARVESTER
- We build the machines that work.
1811/682/782/1440/IH #4/IH QA 42"
Old 11-14-2016, 06:40 PM
I use beeswax in the shop, It works well on exhaust manifold studs that don't want to turn most of the time.
The thing about beeswax, is it withstands a higher heat than penetrating oil.
You can heat it up with a torch (studs/bolts) and keep adding the wax, reheat and do it again.
You can get the studs too hot and they will ignite the wax, but no problem really.
It is a high temp lube sort to speak.
It is an old steel mill trick.
Old 11-14-2016, 06:57 PM
Dirty Steve's Avatar
interesting. Never heard of that before. Thanks for the link.
Old 11-14-2016, 07:06 PM
We'll have to give this a try at work, working on these old tractors we've found plenty nuts that wouldn't budge.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 11-14-2016, 07:41 PM
BTDT,wax on the head bolts on the old kohlers it works on well,remember wax on then wax off.
