Old 11-27-2016, 06:11 PM
smalljob's Avatar
smalljob smalljob is offline
Default New to me Cub Cadet 100
I introduced myself a few days ago when I picked up the 100. http://www.onlycubcadets.net/forum/s...ad.php?t=46708
My plan is to do a complete restore so I am looking things over to formulate my plan. I have some experience with restoring garden tractors, but this will be my first CC and I am very excited about it. First impression of this little tractor a very good. Thanks to some pointers from members here I have found a lot of things including some manuals.
For starters I have a couple of questions that I don't see referenced or I missed it.
The first is on the dash/ pedestal. I know I am missing he key switch which I believe goes in the lower hole (arrow). My questions are:
What is the upper hole that I have circled? Searching the internet I have seen others with the hole also but I don't know what should be there???
What is the red bulb? From the back it looks to be just an empty lens.
Frame near the brake clutch.
What is that that looks like a switch of some type? The rod running through it does move in and out.
Old 11-27-2016, 06:22 PM
Other 100 owners will chime in to verify but I'm going to say that upper dash hole not supposed to be there, light is add on, original key switch hole looks to have been enlarged, should be a D hole. However, the thing behind the brake may end up being an add on old school safety start or brake switch cable activated, looks interesting, maybe a dealer add on.
Old 11-27-2016, 07:51 PM
john hall's Avatar
Hole in black part of dash is not for the key switch, it goes in the pedestal portion, across from the pushbutton for the starter. Note--don't use my pic for anything else other than the switch locations. That Cadet is more mixed up than a Johnny Cash Cadillac
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-27-2016, 08:29 PM
RedHawCadet RedHawCadet is offline
Here's my 100 dash and tower...
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 11-27-2016, 09:13 PM
Terry C's Avatar
Terry C Terry C is offline
Looks like you have two large holes and two small holes to fill.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-28-2016, 12:06 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
100's are my favorite!!
You have a few extra holes and additions. (normal after 50 years!)
Several members have provided good pictures.. all you have to do is fill a few holes and add a few switches..
That thing on the side has to be something aftermarket
Keep us posted!!
Jay
Proud owner of the following:
Old 11-28-2016, 12:50 AM
smalljob's Avatar
Thanks guys I suspected as much, but wanted to be sure. Funny that I have seen at least two other pictures with that hole in the dash, one on a tower for sale on eBay and the other in a YouTube video on 100 restoration.
Old 11-28-2016, 09:11 AM
jaynjeep's Avatar
i've got a 123 with the ign switch moved up on top of the dash like yours.. I think the decal may be a bit mis leading to people.. it says ignition just like it says choke on the other side... so people drill a hole and put it up there to match the choke... that's just a theory.... but it sounds good!
Jay
Old 11-28-2016, 09:31 AM
Bamafan Bamafan is offline
Inactive Member
http://www.onlycubcadets.net/forum/a...1&d=1480294108
Nice seat John Is that OME for that year cub.
[B]Larry[/B]
Old 11-28-2016, 11:07 AM
smalljob's Avatar
I suspect you are correct. I just can't figure out why they think they need two holes. I did see one picture someone mounted a toggle switch in the upper hole. Not sure what it was for however.
