Old 03-04-2017, 11:37 AM
ambrola's Avatar
ambrola ambrola is offline
Default Fuel Line
Does anyone know where I can get a stainless or copper fuel line for the K161? I had 1 spare and used it, now need 1 more? Is there a supplier or a chance someone has one in their spare parts?
Old 03-04-2017, 12:22 PM
You can buy 1/4" (OD) usually at any Hardware Store.
Old 03-04-2017, 02:13 PM
ambrola's Avatar
I need the whole works? Line and nuts.
Old 03-04-2017, 02:28 PM
mortten mortten is offline
http://m.ebay.com/itm/Cub-Cadet-125-...%257Ciid%253A8
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 03-04-2017, 03:15 PM
Dirty Steve's Avatar
Is it the same as steel brake line? Not sure about the brass nuts though.
Old 03-04-2017, 04:22 PM
Got one on the bench right now. And no, it is not for sale. Hard to read but the OD is 3/16 and a 1/8 drill bit fits inside.
Old 03-04-2017, 04:57 PM
If it is 3/16" OD, there is Copper tubing that size. That may be a tad harder to find. Usually a HVAC/R type of business carries it. I know I do.
Old 03-04-2017, 09:09 PM
ambrola's Avatar
Originally Posted by mortten View Post
Will that one work on a 7hp Kohler?
Why not? One of you guys who knows how to make one should help me!
Old 03-04-2017, 11:22 PM
Looking at the picture Dirty Steve put up the 7 must be different than the 10 and 12. Join
Doug
QA-36A
42" blade
Old 03-04-2017, 11:24 PM
I made mine for the "O" Ronnie. But I'm not going through the whole thread trying to find it. Sorry... I used copper tubing. Pretty easy to make, just take your time, so not to kink it. Never good when it gets kinked.
Nuts I got from "somebody"
