Old 03-05-2017, 11:30 AM
mfeldmann mfeldmann is offline
Default Brush hog
I have two questions. One I just purchased L42 Cub Cadet brush hog. The front seal started leaking , the oil in the gearbox is white. Not sure if it's condensation or water what type of oil is used in the gearbox? The second question is the three point Lift will barely raise the brush hog even at wide open throttle. Is there an adjustment for the pressure to raise the brush hog higher?
Old 03-05-2017, 11:39 AM
The actual model for the L42 rear mower is... 190-349-100
Since you make no mention of the tractor this mower is mounted to, I am going to "assume" it is a Cub Cadet Hydro model. With that in mind, first thing I would do is two fold. (A) Change the Hydro Filter, and then (B) check (top off) or install new Hydro Fluid in the system.
Old 03-05-2017, 11:43 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
mfeldmann, according to my L42 owner's manual (190-349-100) "Add EP80W-90 gear oil (Cub Cadet part no. 737-3033 recommended) until it is level with the check plug hole on the side of the gearbox. Gearbox capacity is 30 ounces.
If what you have is white, then it most probably has water mixed in with it. I would think your standard EP80W-90 gear oil would work fine.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 03-05-2017, 11:53 AM
Thank you both for replying so quickly. The tractor is a 1772 diesel. I have an adapter made that picks up the front of these fully loaded Cub Cadet with ease. When I first got the brush- hog it picked it up fine. The hydro fluid has been changed with a new Cub Cadet filter. I have a brenley 12 inch plow the tractor picks it up fine. Don't know why it picked up the brush hog at first now it won't. I've heard of checking the pressure at the hydro pump and shimming it. Anyone ever hear about that.
Old 03-05-2017, 12:09 PM
The 1772 used the Sundstrand U15 Hydo Pump. The same used in all IH built tractors. You can look through any (IH built) Cub Cadet Service Manual that uses the Sundstrand Hydro and it explains the check out, Pressure Testing, and procedure to increase pressure (if needed).
IE... 1772 Service Manual
Old 03-05-2017, 12:15 PM
Thank you so much I do have the manual and I'll search through it now you guys have been very helpful thank you again.
Old 03-05-2017, 01:17 PM
If it suddenly stopped picking up the mower, it likely just needs a fluid and filter change. Don't mess with checking pressures until you've done that.
Old 03-05-2017, 04:20 PM
You mentioned you had an owner's manual for the brush hog. Is it on a PDF file?
Old 03-06-2017, 08:15 AM
FrankF3's Avatar
No it is not PDF yet. I can try to do over the next day or two. When it is maybe Roland can put it in the library if it isn't there yet.
Old 03-06-2017, 09:11 AM
Default Brush hog
Thank you so much I appreciate the effort put into it. I'll see if I can access the library I'm not too good at this LOL
