Old 04-02-2017, 08:31 PM
IHinIN IHinIN is offline
Default Cubs retired from mowing
My Cubs are semi-retired from mowing duty as of today. I inherited my dad's County Clipper zero turn and went and picked it up today. It's a 2011 Jazee with 48" deck and 20 hp Kohler. It should cut down on my mowing time considerably.
Old 04-02-2017, 08:38 PM
Is that a single joystick to drive with?
Old 04-02-2017, 09:52 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
I do like knocking out 4 acres in 2 hours with the Scag, but I still have to find sometime on the Cubs. Hope the zero turn works out for you.
Old 04-02-2017, 10:52 PM
Lanceskene's Avatar
Lanceskene Lanceskene is offline
Nice... you will likely see your mowing time cut in half or maybe even less. I personally still prefer a steering wheel so for a couple years now Ive been using mowers with a front mounted deck and rear steer but the time saving is comparable to a ZT.
Lance / Alberta Can
IH 127 w/deck, snowblade
IH 154 Loboy(x2) w/creeper 3pt and 3160 deck
CCC 12.5 w/deck
Plus 35 or so non IH tractors
Old 04-02-2017, 11:44 PM
Originally Posted by Lanceskene View Post
Nice... you will likely see your mowing time cut in half or maybe even less. I personally still prefer a steering wheel,,,
I would own a diesel ZT in a heartbeat,,, except for one issue.
We have had a number of neighbors flip ZT's,,, and several more slide the ZT onto a busy road!!
The combination of damp grass,, hills/grades,, and whatever other factors keep a steering wheel in my hands.
NO ZT 4 ME should be my license plate,,
Old 04-03-2017, 01:36 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
I like the Zero Turn mowers and I agree they are a bit faster, But I still like to run my older Cubs just for nostalgia. Plus anytime I am mowing in the front with a Vintage Cub, I get all kinds of honks and thumbs up from the people that drive by!!
Jay
Proud owner of the following:
Old 04-03-2017, 01:47 AM
Lanceskene's Avatar
I have a Kubota F2000 right now you might like, 3cyl diesel with a 60" front mounted deck, 4 wheel drive hydrostatic with a front diff lock. Still alot of work to do on it but I just need a belt for the deck and it will be ready to test out when the grass gets green.
Ive used quite a few ZTs and they are nice as long as the lawn is fairly even and smooth otherwise they can be a rough ride. Theres a nice 48" Gravely ZT over at my shop but at home I like front mowers with bigger tires.
Lance / Alberta Can
CCC 12.5 w/deck
Old 04-03-2017, 05:56 AM
Yes it is. It will take a while to get used to.
Old 04-03-2017, 05:59 AM
I've heard of issues with ZTs and hills but my yard is flat so I don't forsee any issues.
Old 04-03-2017, 10:57 AM
Lanceskene's Avatar
With the Gravely ZT at the shop Ive noticed it can leave ridges in the finished cut if the deck is lower on the front so I keep it adjusted closer to perfectly flat, about 1/8 inch lower instead of 1/4 like I do on GT mounted decks.
Lance / Alberta Can
CCC 12.5 w/deck
