Old 05-26-2017, 10:39 PM
pvolner pvolner is offline
Default Noisy 60 inch Haban deck
I had to pull my super out of retirement the other day. I haven't really used it for a couple of years now. I have been mowing with a zero turn and kinda got spoiled. Anyway my zeroturn has engine problems now. Anyway back to the 2072, I charged the battery and I'm back to mowing grass but the deck bearings are like screaming. I have greased them but it's not helping i guess they went dry from sitting. Any tips on replacing them or better bearings?
Old 05-26-2017, 10:56 PM
You sure it's not the belts?
Old 05-26-2017, 11:00 PM
I thought it might be the belts and or the guards rubbing the pulleys but it's the bearings.
Old 05-27-2017, 12:16 AM
So you took the belts off and spun them by hand, and they do not turn free and/or "grind"?
I'd put more grease in them. The possibility that they all 3 failed at once due to non use is extremely unlikely.
Old 05-27-2017, 05:20 AM
Dirty Steve's Avatar
http://www.onlycubcadets.net/forum/s...+deck+bearings
I have used the bearings Sam mentions. They work great. Just remember to address the dust covers.
Old 05-27-2017, 07:01 AM
john hall's Avatar
What he said!
I've got 2 Habans, never rebuilt spindles in either. One of them is a lot noisier than the other. It probably needs new bearings, but has been running "loud" for a couple seasons, no slop in any of the spindles so I'm going to keep running it a while longer.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 05-27-2017, 08:11 AM
Threads on the care and feeding of the Haban decks. LOL
http://www.onlycubcadets.net/forum/s...ad.php?t=33020
MRC 205 SZZ
Pacamor 6205 Z 52 MM OD X 25MM ID X 15MM wide
VXB.COM 1-800-928-4430
8 Bearing 6205-2RS 25x52x15 Sealed Ball Bearings
Price: $31.37
Code: Kit487
http://www.vxb.com/page/bearings/PROD/Kit487
Old 05-27-2017, 09:28 AM
All 3 of them will spin by hand. The discharge side is making all the noise. This is the old style haban model 374.
Old 05-27-2017, 09:31 AM
Berwil's Avatar
Berwil Berwil is offline
Did you check the tensioner pulley bearings ( I am assuming it has one). On my 44a (completely different I know), the un-greasable tensioner pulley started roaring and it made the deck so loud I thought I was going to have to replace spindle bearings.
Bill
Old 05-27-2017, 10:20 AM
Bill
You can grease those if you use one of these.
https://shop.advanceautoparts.com/p/...SABEgLklfD_BwE
