Old 06-20-2017, 05:22 PM
rdehli rdehli is offline
Default Cat 0 install question
Istalling a cat 0 hitch on a buddys CCC tractor . got 1 bolt on the axle housing that will not tighten up. What are the options ? thanks much
Old 06-20-2017, 05:48 PM
Rdehli, I'm not sure which bolt you are talking about or if you are working on a GT or a SGT but I'm probably going to say you will need some type of threaded insert or maybe tap it to the next size if possible. Probably a good idea to install a set of rear braces too.
FWIW, I have a stripped out bolt on my 882 and I have not had any issues yet. I use Permatex #2 on all bolts. Someday I'll repair it.
Old 06-21-2017, 01:04 AM
I had that issue on a tractor I bought. The PO put a longer bolt in with a nut on the inside. Wasn't my cup of tea, but it worked for him...
I installed braces.
Old 06-21-2017, 11:39 AM
dbuck dbuck is offline
Smile
What are these braces that Oak and Zippy are talking about?
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 06-21-2017, 03:18 PM
Dirty Steve's Avatar
http://www.xtrememotorworks.com/Part...Cub-Cadet.html
These gems will fix your ailing Cub's arse!
