Old 06-22-2017, 08:23 AM
Jmcda007 Jmcda007 is offline
Default 2182 Starting Problems
Hello Gents,
I am having an issue with my 2182 starting. I have the key and push button start on this rig and I started it up yesterday and it cut off immediately. Now it wont start at all but it will crank over. It seems to be an electrical issue but I am just wondering where i should look first as to if there is a common issue? I think the key switch is okay but who knows. All i know is when i turn the key over and get ready to start, i should have the fuel pump running and the low oil light on but i dont even hear anything click on when i turn the key switch on. It turns over. I have voltage going to the switch. Any suggestions? Anyone's help is really appreciated. Thanks!
Old 06-22-2017, 02:19 PM
Well if you have a push button to start it someone has messed with the wiring so I have no idea what you have.
Where are you in VA?
Old 06-22-2017, 03:44 PM
@ Sam Mac
Well I have been using this mower for a while now and this was just all of a sudden. This looks to be a factory install push button but I could be wrong. I dont know a lot about this tractor but i know they key switch is factory and all the connectors havent been messed with as far as i can see.
I live in King William, VA
Old 06-22-2017, 04:00 PM
The 2182 did NOT roll out of the Factory with a Push Button start. Everything was incorporated in the Ignition Key Switch. This indicates that someone thought that part of the Ignition Switch was bad. In my world, if one part of the Ignition Switch is bad, then the whole damn thing is bad.
Like Sam said, someone has altered the wiring and thus it is hard to see and say, what they did.
IF.....this were mine, I would get the OEM Ignition Switch and return the wiring back to the original design.
Terry C's Avatar
Terry C Terry C is offline
I will guarantee that push button is not factory.
Let's see some pics of the wiring.
Check for corrosion on the terminals of the switch.
Better have a VOM handy.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 06-22-2017, 04:24 PM
I will try to send some pictures later. I didnt have a lot of time yesterday to read everything out. I am thinking it is something to do with the interlock from looking at the electrical diagram. The wiring on this Cub doesnt look the best. The guy let it sit for a while but i havent had any issues since i bought it last year besides some engine issues that i have repaired. I agree, I would have spent the $30 to get a new switch.
