Old 07-13-2017, 11:07 PM
familytime familytime is offline
Default Kubota WG600 still wandering
Put a new distributor in today. Got a new kubota one with cap and rotor for $360. Engine runs significantly better. The misfire when hot it gone. The engine is nice an smooth. It still wants to wander some and then smooths out, then wanders again. Its only when off load, mostly when idling so not a big problem at this point. At least now it stays running. Carb has been cleaned, fuel cut offs cleaned, all new fuel line, new fuel pump, new fuel filter, and new plugs and as found in a post from Sam, I made sure the governor was set correctly.
Old 07-14-2017, 07:33 AM
The one I had that did that was because the spring would get into a harmonic vibration. It needed just a 1/2 twist of the spring to make it stop. Pic is before I twisted the spring.
Old 07-14-2017, 08:31 AM
Dirty Steve's Avatar
Got it on the run now!
Old 07-14-2017, 10:56 AM
Terry C's Avatar
Terry C Terry C is offline
If sams suggestion doesn't fix it, you can richen the bottom end. Top is set unfortunately.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Tags
2182
