Old 07-26-2017, 09:23 PM
Chucks ss Chucks ss is offline
Default PTO stuck engaged
I have a model 123. I finally got right belt for the deck and i guess the pto is stuck engaged (blades don't stop turning)/. Any tips on getting it unstuck or do I need to replace it?
Old 07-26-2017, 09:29 PM
Can you post pictures of the PTO and the arm?
Is the PTO button on the PTO there? Is there a button on the arm? With the arm forward, how much space is between the PTO and the arm?
Old 07-26-2017, 09:46 PM
There is a button on the flat bar in front of the pto. With the pto lever forward. There is 3/8 inch gap. The lever ect sewms to be fine. This 123 has sa5 for years. The actual pto itself is turning along with pully and wont disengage
Old 07-26-2017, 09:53 PM
Is there a large gap with the lever in the forward notch? ( it will move forward past that notch )
Old 07-26-2017, 09:59 PM
Yes actually. The lever will move forward past the notch
Old 07-26-2017, 10:03 PM
I did not explain well. With the lever in the forward ( not past ), is there a small amount of clearance?
With the lever back, are the three arms that compress the spring ( held by the PTO button ) deflecting the spring rearward?
Old 07-26-2017, 10:16 PM
Gompers Gompers is offline
If the little arm isn’t swinging back to compress the PTO clutch, you can probably just adjust the turnbuckle between the PTO lever and that clutch arm dealie. If it IS compressing the clutch when it’s all the way back, then you’ve got other problems
Old 07-26-2017, 10:23 PM
I will adjust turnbuckle first. If it doest press hard enough then on to next thing. The boss says i have to go inside for the night. Lol. Till tomorow guys thanks. And also if its easier to talk on the phone. I will give u my number. Just let me know thank you.
Old 07-26-2017, 10:31 PM
Terry C's Avatar
Terry C Terry C is offline
Sorry didn't notice you were from IA. What part you from? NW is where I am.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-27-2017, 02:43 PM
Ankney. I moved here from Illinois 12 years ago. I love Iowa.
