Old 08-02-2017, 02:52 PM
Pequeacubs's Avatar
Pequeacubs Pequeacubs is offline
Default Trunion Repair
Would anyone be able to give me the dimensions of the trunion repair bracket i have access to a mill and would like to build one for my 107 thanks
107 w/ 75lb IHC wheel weights 3pt. hitch spring assist lift.
1810 w/spring assist and brinly cat.0 3pt hitch w/A frame adapter and sleeve hitch now an 1811 cab and 551 blower
1000
42" spring tip snow dozer blade,qa36a snow thrower,#1 tiller w/1 ext., brinly 10"moldbord, 3pt.cutivator,brinly disk,#1 trailer #4 trailer, 2 sets of Ih weights
windbreaker soft cab,qa42" snow thrower
my grand fathers 67' j.d.110h with brass tag 6 way snow/dozer blade
67' WH lawn ranger
Old 08-02-2017, 03:03 PM
Is this what you are looking for..??
Old 08-02-2017, 03:49 PM
Pequeacubs's Avatar
Yes thank you very much
1000
67' WH lawn ranger
Old 08-02-2017, 03:55 PM
Pequeacubs's Avatar
do you know what the dimensions of the piece of flat steel to use by any chance
1000
67' WH lawn ranger
Old 08-02-2017, 04:06 PM
cubs-n-bxrs's Avatar
1/8th would be pretty close to the thickness you would need.
Old 08-03-2017, 08:20 AM
Pequeacubs's Avatar
Thank you.
1000
67' WH lawn ranger
Old 08-05-2017, 10:24 PM
Gompers Gompers is offline
I whipped this up today as I was working on mine
Old 08-05-2017, 10:41 PM
You guys know that Aaron at xtrememotorworks.com sells the repair for these for $11.50 right? I mean, I own a lathe, but I'm not going to spend an hour making a part I can buy for a little over $10.
http://www.xtrememotorworks.com/Part...Cub-Cadet.html
Old 08-05-2017, 11:47 PM
Plus $7 shipping.
Couple tacks with the welder in the corners, and a little file work in most cases, good to go.
Old 08-06-2017, 09:13 AM
Plus $7 shipping.
$18.50 is still worth it in my book. But I agree.... a couple "blips" with a welder in the corners usually fixes them up.
