Got nine of the cubs out for some exercise today, it was such a nice day here in eastern Virginia. The other two (a 1450 and the 109) are at the other house, so they didn't get to play today.
Had a slow leak in the 108's left rear tire and the 72's right rear. I plugged a hole in the 108's tire last month, and could not find any other leaks, but after a couple weeks, it was quite low on pressure. So I put a tube in it today. The 72 has had a slow leak on the right rear for over a year, so finally put a tube in that tire today as well. The 149 has a PTO problem as the PO drilled out the pressure arm where the fiber button goes so it is way oversize. I put a new button on it with a sleeve to hold it in the hole, but it self destructed pretty quickly. Need to order a brass button from Jeff in PA. (I think that's who sells them). Put Stabil in all the fuel tanks, and let them run for about 30 minutes. Three of the nine needed to be jumped, but they all started and ran fine. When I put them back in the garage, I shut off the fuel and let them run the carbs dry. https://youtu.be/uLBKx7_z1oo
Nice collection you have there. Love that red 148!
Nice. I have enough of a hard time keeping one running. It stalled on me twice in the past two weeks. My fault for not putting gas in it though................................
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
I mowed with the 1211 today and was gonna get the rest out just to let them run a bit but i was to lazy.
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
I try to run the cubs at least twice a year. I only buy non-ethanol gas and I treat it with Stabil to try to keep it fresh. I don't usually keep the fuel tanks full, though. I shut off the fuel valves so a faulty carb float doesn't dump a tank of gas on the floor. BTDT. Not good in an attached garage.
Nice lineup Frank!
Up to 534 and counting... I give up updating my profile! |
Very nice collection Frank! Cool to see them all out and together!
