My 782D runs great. But the Electric PTO kicks out after 30 mins of mowing. The blades will just stop. I replaced the PTO switch itself same thing. The next move is to remove the PTO itself clean and inspect than set air gap and cross fingers. My research found the electric PTOs are NLA
I think that means you need to adjust the air gap.
Hello, clean the plug in spades on your key switch. Other switches also. Just had this happen to me. (682 /ch18/682pto/ 2185 key switch& harness)Mike
I think cleaning the spades and setting the air gap will be my next move. If it still does it i think i will replace it. if i am lucky enough to find one. The 782D uses different clutch that the gas models i believe
Xtreme motor works? Cub cadets website says NLA
http://xtremeope.com/?gclid=CM_97eyHvtYCFRWBswodCxUGQQ
Just type in your part number in the search box.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights . {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
You have to look up the PTO under "PTO and mounting". Item #5. Hang on to your arse! http://www.cubcadet.com/equipment/AR...0-A/0025600011 I highly doubt the coil is bad, but it could have a break in the coil that only opens when it gets hot. I'd go to xtreme for a new one if I was in the market. May look different, but will work the same, and cost much less. |
![]() ![]() o. Plus plus they have awesome customer service. Just be sure your voltage is correct, they will work with it not but will not last long.
126 in surgery with weights, spring assist, 3 point and sleeve hitch 100 with woods finish mower and rear lift, Nice 125 with super nice sweepster, 1782 Super Diesel, 1650,782D in surgery, 102 parts tractor.. 3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
