Old 06-19-2010, 09:53 PM
super1914 super1914 is offline
Default Broken Lift cylinder?
I have to assume this is why the 1914 doesn't have a whole lot of lift travel. It appears that the mounting hole on the cylinder has broken and completely elongated to the point that I can move the cylinder off of the mounting bolt by hand when there isn't pressure on the cylinder. By the looks of things, this has been broken for quite a while. Cub's website lists the cylinder at 275 bucks and the cylinder housing is NLA so a rebuild doesn't appear to be realistic. Anyone have any ideas to fix or modify this? The cylinder still works fine....Has anyone found a cheap replacement cylinder that works for this application if all else fails?
Old 06-19-2010, 09:58 PM
I may have found an option. One of the site sponsors have a lift cylinder from a 1782. Would this fit mine?
Old 06-19-2010, 10:12 PM
Either get that welded or find another...any 82 series through cyclops lift cylinder will work, 1782 included. They are very plentiful used.
Old 06-19-2010, 10:31 PM
Thanks guys. I will have to ask a couple of buddies that weld to see if they can hook me up with a fix. It might just be easier to pick up a used one for 60 bucks if it is going to cost 50 to fix this one.
By the way....at one point I ran across a post that someone put a spacer on the mower lift arm (the one that the cylinder pushes on) that would allow the lift to raise a little higher. I figure if I am going to be working in there, i might as well put that modification in at the same time. I have searched the last couple of days and cannot find that post. Can anyone steer me in the right direction?
Old 06-19-2010, 10:37 PM
http://cubfaq.com/82lift.html
I need to make a half-dozen of these for all of my tractors. No dimensions are provided, so I think we're on our own. I bet I can put a grid on that drawing and get dimensions and make a drawing...
Old 06-19-2010, 10:50 PM
Awesome...thanks. If you get it done before I do, let me know the dimensions.
Old 06-19-2010, 10:52 PM
I may get to it soon...my 782D has to come apart partway to weld something that broke on the 3-point. Might as well add that thing and see why it steers so hard while I'm at it.
Old 06-19-2010, 10:58 PM
jbollis's Avatar
jbollis jbollis is offline
If you were to make some extras, I would be interested in a couple.
JOE
Sold everything but one.
Old 06-19-2010, 11:17 PM
aagitch's Avatar
aagitch aagitch is offline
What decks are you guys using? I've got plenty of lift on both the 782 and super. Is it deck specific?
Old 06-19-2010, 11:20 PM
My 46GT could use more because that deck is really tall. Have you ever had a QL? The lift goes up so much further.
