Old 03-24-2018, 10:22 PM
mach1's Avatar
mach1 mach1 is offline
Default 1782
I bought this tractor almost 10 years ago. It came with a 54” deck and mowed like a dream. About 5 years ago it just stopped in the middle of mowing the front yard. No indication that it was even getting and juice from the battery. I fiddled with it for a bit but could figure out what was going on. I then got side tract working on restoring a 1970 Mustang Mach 1 and the Cub got pushed to the back of the shop. Well I finally decided to start trying to see if I can get it going again.
File Type: jpg AEAB3FB9-EF5E-4E2C-B240-DF126E45AD60.jpg (32.0 KB, 523 views)
File Type: jpg 11809241-9446-4679-846D-6201875D9E9E.jpg (31.7 KB, 516 views)
Old 03-24-2018, 10:31 PM
V30crewcab V30crewcab is offline
good machines, except for the wiring. hopefully you can figure it out easily. Do you have a wiring diagram?
heres one in this link: http://www.onlycubcadets.net/forum/s...ad.php?t=14445
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 03-25-2018, 06:56 AM
IHCubCadet147's Avatar
Good luck. Hopefully it's something simple.
Old 03-25-2018, 10:04 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Cool cub, welcome to OCC
1- 1200 in pieces
1- 1864 in pieces
Old 03-25-2018, 01:25 PM
Dirty Steve's Avatar
(of your Mach 1)
Maybe you could post some pics of the car in the General topic section.
Old 04-03-2018, 09:25 PM
mach1's Avatar
Default Broken plastic
Has anyone had any luck with plastic welding? If so, any tips?
File Type: jpg CFC38D1A-D25C-4869-91D8-C69DF7704C30.jpg (20.7 KB, 422 views)
File Type: jpg 9AE0C020-846E-47D0-AA45-EDCB78C80496.jpg (17.4 KB, 415 views)
Old 04-03-2018, 09:42 PM
You will have much better results with a quality epoxy than with a plastic welder. Sand the area with 150 grit and v out the cracks and then clean it good with rubbing alcohol before applying the epoxy.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-03-2018, 10:02 PM
Rescue11's Avatar
Do what you want, but I have decided to just start buying new. In the grand scheme of things, a guy spends more time screwing around trying to fix this crap then sitting on pins and needles hoping it will last another day. Considering what a new machine costs, I have deduced one can spend some money to have a nice looking, good running machine that is way better and still save lots of money. But then again I'm not just mowing, and I love hydraulics
https://www.cubcadetpartsnmore.com/m...78-grille.html
1- 1200 in pieces
1- 1864 in pieces
Old 04-03-2018, 10:11 PM
john hall's Avatar
If that's the grill, do yourself a favor and order a new one. I replaced one on a 2284 last summer. The old one was literally shattered and fell into a gazillion pcs when I removed it. You might band aid it for a while, but what are you going to do when it breaks again and the price for a new one has gotten higher or the part is NLA?
FWIW, I had to trim some flashing to get the new grill and old hood to play together without snagging and popping.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 04-05-2018, 09:00 PM
mach1's Avatar
I have a nos so no matter how it works out I will have a back up. I was just thinking sooner or later someone will have to figure a way to rescue pieces if possible. All that said I have a plastic welder that I got from a friend. I have no experience with it and he is no longer with me to give tips. I’m going to try it but I was hoping for some advice on best method.
