Old 04-22-2018, 01:20 PM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Default 1811 M18 quit, cranks and doesn't start.
The wife was mowing the other day for about 45 minutes and the 1811 quit. I tried starting it, cranked fine but nothing. Loaded it up and brought it home. When home it started right up. Got it out yesterday started fine mowed for 20 minutes then turned it off. Went to restart it and get it in the garage. Cranked and no fire. Hit it with a little ether and not even a cough. So it must be a electrical issue. Open to ideas of most common issue.
Old 04-22-2018, 01:40 PM
Clay,
that is a text book description of a magneto coil going/gone bad.
If you take the white ground wire a apart at the connection near the coil and still no spark, you just about nailed the cause.
Typical problem is they will start cold, and you can mow/work.
Then stop for a personal 5 minute break, and it will crank, but no spark.
---Been my findings anyway
The engine comes out, to remove flywheel cover, while there, get the junk out of the fins and packed around the coil.
Also blow the chit out of the stator and of course look for anything else like the
crank seal condition.
Old 04-22-2018, 02:10 PM
john hall's Avatar
Clay,
What he said. My question is where to buy a coil? A couple folks in recent months here have gotten faulty new coils. Considering the labor involved, I'd go name brand if its possible. I'd even price Kohler if the machine is a keeper.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 04-22-2018, 08:43 PM
Yep that's what I was afraid of. Time to pull the motor. Good thing I have more than one Cub.
Old 04-22-2018, 08:49 PM
Do check the white mag kill wire, they can abrade on the tin work, especially
if the grommet is missing where it and the plug wires, enter the housing.
Old 04-22-2018, 09:05 PM
While you have the engine out here is my list of suggested work.
Remove tins and degrease motor.
Remove flywheel and clean the stator with compressed air.
Remove heads and resurface, clean carbon off pistons.
New head gaskets and valve seals.
I suggest this work because the head likely leak a bit at this time and it will be far easier to do it now then to pull the engine again later. I have info for economical head gaskets and valve seals in the parts section.
http://www.onlycubcadets.net/forum/s...ad.php?t=50014
http://www.onlycubcadets.net/forum/s...ad.php?t=50013
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-01-2018, 10:04 PM
And why would we pull the flywheel?
2-1811's
1872
2072
Old 05-02-2018, 11:07 PM
OldSkull's Avatar
OldSkull OldSkull is offline
Holy Moly! How the hell this engine manage to run with that dirty magneto is out of my understanding. It looks like an elephant poop in there
Gilles.
1963 100 (red)/in storage
Old 05-03-2018, 06:33 AM
dale c. dale c. is offline
check the magnets on the flywheel to make sure they're not loose . very common problem . if loose be sure to keep them in order correctly or the charging system won't work correctly
Old 05-03-2018, 08:05 AM
To add to that, they not only have to be in proper orientation, of north/south but the spacing between them needs to be correct.
If loose, they can be re glued with epoxy.
