First time poster, I’ve been lurking and searching the forums for info on a free 2160.
It came with a leaking axle seal that I have fixed, and refilled with new 20-50 synthetic hydrostatic oil. It doesn’t have a filter, although the housing looks like it had a place for one. When I place the machine in any gear it is slow to start moving and then will accelerate to a good speed, while holding the foot lever all the way engaged. Any ideas as to the fix? From what I’ve read it sounds like the clutch, is there a write up on how to service or replace it? Thank you for any help. Mike |
I recall seeing a thread about shimming the AGS on MTF My Tractor Forum a few years ago. Just my 2 cents, I would not waste my time on an AGS machine. Pull the engine and sell it for a repower and haul the remains to the scrap yard. Not trying to be a dick just don't want to see you waste a lot of time and $$$$
Sam is right on the AGS.... Previous Owner may have used it as though it was a hydro and burned the clutch(s).... seen that on a few.....
Thank you for the information, the previous owner indeed used it as a hydrostatic. I have nothing into it and with all the attachments that I have with it thought I would try and fix it and make a buck.
I saw the same thread on adding a shim to it. If a clutch wasn’t too tough a job I’d replace it. |
