Old 06-24-2018, 08:44 PM
cooperino's Avatar
Default New Cub House
Wife gave the thumbs up to a new "shed" today.... gonna be larger than the typical 8x10. Thinking about using reclaimed lumber for the build but have to do some research. I'm thinking of building it 12x16 and a little more headroom. Than typical for a crane beam down the middle of it. I will start with making some drawings and post some progress.. I'm calling it the "Cub House" after the wife said I wanted a club house lol. Anyway, should make for a respectable place just for Cubs. My detach is full of other toys and she wants her car in garage for the winter... anyone here ever do a reclaimed lumber project? Would love some input with working with old lumber..
Old 06-24-2018, 09:06 PM
I've used "reclaimed" lumber a million times to build things. It builds the same as anything else. Unless your using oak... then good luck. Only tip: get all the old nails out. They're hard on saw blades.
Just my but I'd make it bigger. Twice the size you think you need will still be too small in a year or two of use.
Here is the shop my brother uses. The main building is the shop and we added the lean-to when I went on that trip. He since added another lean-to (same size) on the other side. He still needs more room.
Old 06-24-2018, 09:31 PM
My shed is 12x16 and has a 4' tall loft for storage. It's not to bad to work out of if its kept clean, I can get 3 Cub's in it but have to move 2 out if i need to work on one. Here's a thread with some pics of my setup.
http://onlycubcadets.net/forum/showt...light=workshop
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 06-24-2018, 09:48 PM
SLS327 SLS327 is offline
Congrats on the shed build!
I have a shed built from reclaimed lumber, only thing i have to add is not to sacrifice integrity on lumber size, shape because its used.
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 06-25-2018, 12:42 AM
I agree with Jon, think as big as you can afford, and usable space, cause when you're done building it, it becomes to small real fast...
Old 06-25-2018, 01:36 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
I agree with Todd and Jon.. make it bigger.. 12x16 will get small in a hurry.. no matter how big you build it will fill up..
I built a steel shop in 1998.. original plans were for a 20 x 20.. then a 25 x 25.. found out for just a bit more in materials I could have a 30 x 30 for about $700 more.. cost per square foot was waay better on the 30 x 30
Jay
Proud owner of the following:
Old 06-25-2018, 06:36 AM
cooperino's Avatar
Thanks for the tips guys. I don"t need to go huge. I own a pretty large facility for my company so if I need extra space I turn to that. This is going to be used primarily for working on Cubs and other yard type equipment and not so much for storage. Couple guys I know here said the local reclaimed lumber is really hard and dense. I'm not talking about reclaiming pallets but reclaimed vintage lumber. We have a guy here that takes down old barns, houses, buildings, Etc and reclaims the lumber. You can buy it as is or cleaned and trued up through his mill which is the way I would go I think. Most of what he reclaims is between 100 and 200 years old. I'm sure if he is running it through his mill he is careful with nails. I'll have to take a ride to his yard and see what he's got.
Old 06-25-2018, 07:29 AM
I'm pretty sure here in Georgia you can't use reclaimed lumber on a new structure if it is going to be permitted & inspected. Anything here over 120sf must be permitted so I would check with them first if you are pulling a permit. Hopefully you can just build it and not have to pull one.
Old 06-25-2018, 07:56 AM
cooperino's Avatar
I thought about that. I was thinking I could have an "out" I was thinking of not pulling a permit but I was going to make it so there is a seam In the middle joined together by some steel flat stock that could be unbolted in the event we get assessed. I could just unbolt the flat stock and say it is 2 structures. I don't believe we have a limit on structures under 120SF. I would lap the roof joint so one falls just slightly under the other. The higher of the 2 would be made longer to cover the gap. I really do not think it will be an issue. We got assessed recently for some other work I did so I doubt they will be back to randomly check. Only issue would be if I decided for some reason to sell but that's not likely. My wife is in real estate and she says even if we did want to sell, rather than getting a C/O for it we could "gift" it to the new owner.
Old 06-25-2018, 11:59 AM
We don't have to "permit" to build anything where I live. If you live in the county seat, you have to get a "building permit" to build. But that's basically you paying off the law enforcement to leave you alone while you build. Or give them a reason to stop and ask if you have a building permit....
