I have gleaned some info from searches but I know there are life long experts here that can answer these questions.
I have a 3 point (homemade) with down force option only, so far as I know. I just wanted to have some implements to play with so found a good deal on a Sears single gang disk in excellent condition, built a sleeve hitch adapter for it to hook to my 3 point. After a couple of attempts I am going to assume that a disc needs to float? Is this correct? (wish I would have paid more attention 40 yrs ago on my uncles farm). As always any wisdom is greatly appreciated, and yes I know I probably need a 8" moldboard to hit it with first but this was the first I found. Running a wf, 782 for the record. Thanks, Vic |
All 3pt tillage equipment needs to float. You can't force it into the ground or you lose traction. You need to slot the lift straps if you haven't already.
I have a Brinly disk. They are almost piss-ass worthless. Even on plowed ground, the disc blades have too deep a dish, and can't be angled enough to make it work. I kept it, but I have some ideas for it I just haven't gotten to yet. Yeah, you need to find a plow. The disc will not break ground. It will kind of stir the dirt if you plow first. |
Yes the disc needs to float but that doesn't mean you can't load it with lots of weight to make it work.
btw, is that an 8 or 10 blade disc? |
Odd angle pic, po had rigged up the tow behind for his quad, pic of tag also.
As you can see it's a 10 blade, they are 11.5" in dia. It's all a learning experience for me, wanted something to play with, and was able to build a good sleeve hitch adapter that will hopefully come in handy later, as I'll be looking for a plow, maybe I can find another one and mount them together. I was wondering if slotting the lift straps would work, it seemed right but happy to have someone verify. thanks guys, any other info is greatly appreciated. Vic |
![]() Quote:
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
