Old 08-24-2018, 08:47 AM
mrshaft696 mrshaft696 is offline
Default Cub Cadet 104 Resto
I am starting to finally work on this cub 104 I got basically for free. It got it with no engine and it seems mostly complete otherwise. I am gonna need some help getting it off the ground and figuring out what parts im missing, I figured this is the best place....
I want to use it as a stock class puller maybe in the future but for now I got a engine for it, and I need to start getting the parts together to make it run...
I have a K241 10hp that I need to get going, the first things I know I need are is a belt for the starter & a manual or diagram of how the engine is supposed to be assembled...& I know im missing parts to connect the driveshaft to the flywheel.
here are a few pics... I have a 1450 & a 1811 around as well.
Old 08-24-2018, 08:51 AM
Looks like you're missing the 3 pin driver, does the engine have the screen and drive cup on it?
Where in PA are you located?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-24-2018, 09:15 AM
I will check, I don't recall...
I am in SE PA, Bucks County.
Old 08-24-2018, 09:32 AM
First, welcome to OCC...
Manuals for both Cub Cadet & Kohler are in the Technical Library Section. If you like "paper version", click on Binder Books at the top of the page.
Click on the Tab at the top of the page "Cub Cadet Parts & Service Look-Up" will get all your parts look-up needs.
Old 08-24-2018, 10:08 AM
Thanks I've been browsing the Technical Library- Tractors & don't really see what I am looking for, I assume I am missing something. I see your the other links you referenced.
Old 08-24-2018, 10:09 AM
What are you specifically looking for...???
Old 08-24-2018, 10:22 AM
K241 info, pictures, diagram/parts
And how that clutch assembly should look.
Old 08-24-2018, 10:32 AM
Again, that information is in the TP-2379 Service Manual as located in the Technical Library, page 3, 9th down.
Again, the Parts for the K-241 can be seen by clicking on Link as previously stated.
Again, That is in the GSS-1398 Service Manual for the 1x4/5 Series Tractors as in the Technical Library Section, page #3, 3rd down.
Old 08-24-2018, 10:42 AM
Again, thanks allot
Again, my fault I didn't realize the library was multiple pages long
Again you asked what I was looking for.
Old 08-25-2018, 10:20 PM
This is what is on the engine I got
