Old 10-05-2018, 10:34 PM
Chucks ss Chucks ss is offline
Default Newer member has questions
#1. i sold my 123 hydro i kept the snow blower and blade and im looking at buying another vintage model. can anyone tell me what models the blower and blad will fit on ? for example. does an original have the same mounts ? i dont think it does but dont know.
#2 im looking at an original. a 70 a 100 and a 147. pros and cons anyone ? for example. which has better power ect. weaknesses look forward to this info guys thanks.
Old 10-05-2018, 10:52 PM
john hall's Avatar
I'm not that up on the "OLD" ones, but the 147 should have the largest engine, 14hp Kohler I believe.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-05-2018, 10:58 PM
Gompers Gompers is offline
I’m not super knowledgeable on the non-qa (Pre-1x4/5 models) attachments. I’m pretty sure the original is an oddball though.
147 will be the biggest and most modern of those options. 70 and 100 are basically the same tractors but the 100 would have had a 10hp engine vs 7hp in the 70. Otherwise they are the same. Original is a 7hp. I’d argue that it’s more of a collector tractor than a worker, but plenty of people use them to work.
147 is hydrostatic and the rest of those are gear drive.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 10-05-2018, 11:39 PM
Your attachment's will fit the 70/100 no problem, they will also fit the 147 but will still have to be bolted on since they're probably not quick attach attachments. The original takes attachments that are specific to it.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-05-2018, 11:45 PM
So they should fit any “narrow frame” model:
70/100
71/102/122/123
72/104/105/124/125
73/106/107/126/127/147
Old 10-05-2018, 11:48 PM
dodge trucker dodge trucker is offline
Yeah I guess/ I have all wide frames and QL's and I know that everything is different between them and my son's Original
Old 10-06-2018, 12:29 AM
u guys are awsome. thanks. decisions ugh the original is completely restored and would love it but it would be a shame to put blade on it. prob. going to go with the 100 or the 147 more than likely the 100. ill update and post pics when i decide and pick it up.
