Old 12-03-2018, 10:36 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default 50a mule drive pulley bearings
Bearings are bad on the pulleys of my 50a deck mule drive. They are held in place with snap rings. Only number I can find on bearings is "1623". Have searched the internet and can not come up with a correct match. Also tried search on only cub cadets. Can any one help me out with this? Thanks and have a great day.
Bob
Old 12-04-2018, 12:55 AM
The Mule Drive Idler Pulleys for both the 50 & 50A were Part Number: IH-61176-C92.
Old 12-04-2018, 04:49 AM
Steve N Mi Steve N Mi is offline
For the bearings only you have lots of choices here;
https://www.google.com/search?q=bear...hrome&ie=UTF-8
Google search - bearing 1623 that was pretty easy!
Old 12-04-2018, 05:39 AM
twoton twoton is offline
And the same for the 44 and 44a decks also?
The pulleys with the replaceable bearings are solid machined units. Nice to have.
If you need an entire new pulley, I've been pleased with these Stens units on my Quietlines with model 44, 44a and 50 decks;
https://www.amazon.com/dp/B001OK4J8Y...v_ov_lig_dp_it
Old 12-04-2018, 08:59 AM
Rmowl's Avatar
Rmowl Rmowl is offline
I’ve used those pulleys as well with good results. I’ve also sprayed rough turning pulley bearings on the mule drive with kroil or pb blaster with good results also.
-Rick
IH 782
IH 126
CCC 1863
Old 12-04-2018, 09:12 AM
The Stens aftermarket replacements are cheaper than the $23.71 that Cub wants.
Old 12-05-2018, 02:54 PM
Mr Bob's Avatar
Default mule drive bearing
Thanks for the part# Roland. My Deck is a 50 and not a 50A. My mistake. My pulleys are in great shape and very heavy duty. I am looking to just buy the bearings as the clip into the pulley. Thanks to all that replied and have a great day.
Bob
Old 12-05-2018, 03:04 PM
I am unaware, that you can buy just the bearings for the Mule Drive Pulleys. The bearings are put into the pulley assembly, and then either spot welded or riveted in place. The parts manual makes no mention of just the Bearing.
Old 12-05-2018, 04:38 PM
https://www.onlycubcadets.net/forum/...070#post257070
Old 12-05-2018, 05:20 PM
This is the correct IH-61176-C92 Idler Pulley for the 50 & 50A Mower Deck Mule Drives.
The previous, is a pulley for the "Tiller" Mule drive.
