Old 12-10-2018, 09:29 AM
Woodtrucker Woodtrucker is offline
Default New cub project. First timer and I’m tickled so far!
Had a great friend of mine GIVE me a partially restored 100. I was so excited to get her home and get started.
Here are the things I’m working on and need help with.
-need a 42” IH plow subframe. I have one that is too long that I can hack up and make work if no other option exists.
-I have been able to get the engine to turn over using battery out of my 0 turn. It only has 195 cca’s so I’ll be buying a new battery with 360cca.
-This allowed me to see if the push to start was sending voltage to s/g and all is good there. I then was tracing the voltage to Ig coil but not sure if s/g is sending correct voltage to it. Is that something you can tell just by cranking it over using a meter?
-need a spark plug wire. Would Napa or any other retail carry a cable I could pick up locally that would work on this IC?
That’s all for now! I’m very excited about my new machine!
File Type: jpg 9038B2B7-A5D4-4579-A2E4-9D328FAEC098.jpg (34.2 KB, 166 views)
File Type: jpg 7309AB8F-7472-4C94-B4EE-57512BBA6C81.jpg (23.7 KB, 164 views)
Old 12-10-2018, 09:48 AM
sorner's Avatar
sorner sorner is offline
WOW.. You got a steal!
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 12-10-2018, 10:51 AM
johncub7172's Avatar
Amazing gift! I particularly like the looks of the 100, not being a nice and shinny new paint, but reserving some original paint, and weather wear.
I'd check with the sponsors up above to find a coil high tension lead. An original to the 100 would look better in my opinion.
Whatch-ya got for a serial number?
I do miss my 100, lol!
Old 12-10-2018, 11:17 AM
Ser no: 66758 63-64model, has the 10 horse K241. This thing is cool. Need to get it operational. Restoring is not primary intention and something I’ll do over the years. I would like to get it running ASAP and get my plow attached! What a gift!
Old 12-10-2018, 12:27 PM
3hounddogs 3hounddogs is offline
that is a nice tractor and a great friend you have! good luck with your project. gotta feeling it won't be your only one.
Old 12-10-2018, 12:34 PM
I’m already hooked!
Cub Cadet 100 #66758
Old 12-10-2018, 01:24 PM
Nice looking 100 sir. The ignition coil positive post is powered by the key switch. Yes, using a test light or a meter you should see 12 volts there during start and run. Here’s the diagram
https://www.onlycubcadets.net/forum/showthread.php?t=35
Old 12-10-2018, 02:15 PM
You can use any plug wire to try/test/ start it, they ain't fussy.
Old 12-10-2018, 05:15 PM
Nice 100, that is my favorite.
Up to 534 and counting...
Old 12-10-2018, 05:41 PM
cooperino's Avatar
Great lookin 100. Im sure it will bring you a lot of pleasure!
