I’m reassembling the nose assembly with the lights and grill and can’t recall how the springs hook up to the nose. Is it the little hole near the back corner? I found the hole on the grille insert. Also......did I assemble the lights and upper screen correctly? Is there not supposed to be a rubber grommet around lights....or just an open hole around the wire ?
Try to get the bulb in the right orientation, there are no rubber grommets, otherwise it looks fine.
I do believe the hook end, closed loop, goes to the grill housing.
Got it. Thank you!
