Old 12-17-2018, 01:41 PM
35boulder's Avatar
35boulder 35boulder is offline
Default Mower Deck Removal on 100
Was wondering if anyone had any tips for removing the 38" mower deck on my 100. Note that this is all new to me. As I look at the deck it appears to be attached to white sub frame under the tractor. How much of this needs to be removed and is this a one man job? Also how big a deal is it to re install? Just seems like it would be easier to work on with the deck out of the way. Thanks
Old 12-17-2018, 01:47 PM
Check the tech section under implements and a manual should be there.
Up to 534 and counting...
Old 12-17-2018, 01:49 PM
35boulder's Avatar
Here's a couple of pics
Old 12-17-2018, 01:54 PM
Need pics up front.
Old 12-17-2018, 02:10 PM
35boulder's Avatar
Couple of more pics!
Old 12-17-2018, 02:11 PM
35boulder's Avatar
Not sure why some of them came out sideways. Sorry
Old 12-17-2018, 03:23 PM
The Owner's Manuals are in Technical Library Section as mentioned before. See Link...... Pin on Decks
Old 12-17-2018, 03:25 PM
Gompers Gompers is offline
Lower the deck to the ground, pull out the back two spring loaded pins and the deck will just roll forward and off the front lift arms there. Get the belt off the pulley, raise the lift and slide it out from under the tractor.
Easy one man job.
Installation is opposite of removal.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 12-17-2018, 03:46 PM
35boulder's Avatar
I'm staring at this 100 and for the life of me I cannot see how to remove the belt from over the front pulley without removing the whole front end...am I missing something?
Old 12-17-2018, 03:59 PM
You need to loosen up the adjuster on the PTO disengagement lever with the PTO engaged and slide it out between that and the PTO.
edit: Engine off, obviously
