Old 01-02-2019, 10:24 PM
Aircomet's Avatar
Aircomet Aircomet is offline
Default Home Made Weight box
I decided to fabricate a weight box for my 147 that I recently installed a 42” snow thrower on. I made it out of 1/1” square tube for the box and the mounts were made out of 1/2” rectangle and 1” flat bar. This is all scrap I had cut up from my scrap pile. The bottom has a pice of 11 gauge sheet metal on it.
I made it so it attaches to the bottom hitch plate for the implement with 4 bolts. Then, to keep it from bending down I have 2 supports coming down from the frame where the sleeve hitch mounts up with 2 more bolts.
I plan to use some old car brake rotors and riding mower flywheels for the ballast weight. In addition, I think it may be useful for hauling small tools or gas for the chainsaw and other stuff too. I also welded on a hitch to the back of it in case I need to pull a trailer or get stuck as the factory one is blocked with the box installed.
Cub Cadet 147 (first tractor), 108, Original
Others: Allis Chalmers 710, Massey Ferguson 10, John Deere 110
Old 01-03-2019, 11:58 AM
Nice work on the weight box.
Old 01-03-2019, 01:16 PM
twoton twoton is offline
Dang! That thing is rugged.
I would suggest that you look for a way to tie it into the axle tube bolts for additional support. Especially if you plan on pulling additional items with it.
Old 01-03-2019, 04:27 PM
IHCubCadet147's Avatar
Nice work!
Old 01-03-2019, 04:55 PM
Rmowl's Avatar
Rmowl Rmowl is offline
That looks very nice. Here’s where I have my weight bracket mounted on the frame for my loader tractor with a big piece of iron in it, don’t think you saw that
File Type: jpg 0E681702-3462-4734-B3D9-0B1925B868D7.jpg (19.9 KB, 289 views)
-Rick
IH 782
IH 126
CCC 1863
Old 01-03-2019, 05:15 PM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
Now you can do some wheelies!
Randy
1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift
Old 01-03-2019, 10:15 PM
Aircomet's Avatar
Removed the weight box and sanded it down and painted it today. Just used some flat black rattle can stuff on it because I know it will get all scratched up from the weights anyways. Turned out nice though.
File Type: jpg 48726911-D7E7-40C4-B0B5-D86637BCBB01.jpg (32.0 KB, 269 views)
Old 01-03-2019, 10:17 PM
Aircomet's Avatar
Yeah, I saw that in the background. Looks like it would be very effective. I’m sure with a loader you need all the weight on that back you can get.
Old 01-03-2019, 10:21 PM
Aircomet's Avatar
Thanks for the suggestion. I may fabricate a bracket to go to those bolts on each side at some point. I think for now I’ll be alright as I have no intention of pulling anything heavy with it and most of the force is a shearing force straight down or is taken by the upper mounts.
