Old 01-05-2019, 03:49 PM
Gr8lite Gr8lite is offline
Default Confused ...... a Hydro 1872 question
Model 1872
I just drained ( 3/8 square plug and removed rear cover) the hydro assy.
wiped clean the inside of the rear axle housing , installed new gasket and
bolted cover back on , re-installed drain plug.
Refilled 7 quarts of Hy-Tran into the fill / dipstick tube.
Started tractor allowed for a min of warm up , ( rear wheels off ground)
slowly moved hydrostat lever forward , straining sound in pump , moved
lever back to "neutral" , straining sound stopped , moved slowly to reverse ,
straining sound again. Shut tractor down , no leaks , oil is a proper level on
dipstick.
What am I missing ? ? Tractor ran great and drove good prior to drain
and fill. Thanks for the assistance !
Old 01-05-2019, 03:53 PM
Did you change the Hydro Filter...???
Old 01-05-2019, 03:59 PM
cubs-n-bxrs's Avatar
Sounds like it is air locked. Try rotating the rear tires after you put the directional control lever in forward.
Old 01-05-2019, 04:09 PM
CubDieselFan's Avatar
If the filter was changed, what filter was used? A few years ago someone found a rag left in the rear after the service was done.
Old 01-05-2019, 05:02 PM
Yes I did change the filter. I don’t remember the number right now , but’s it’s a Baldwin filter , we are a Baldwin , Donaldson , and Racor distributor. So I have plenty of confidence in the proper filter cross.
Old 01-05-2019, 05:29 PM
This is the list of filters that work.
Cub Cadet 923-3014
NAPA 1410
Wix 51410
Fleetgard HF6096
Baldwin BT8486
Old 01-05-2019, 07:11 PM
Yea the Cub # crossed to the Baldwin BT 8486 that’s what I installed.
Old 01-05-2019, 07:36 PM
cooperino's Avatar
Was there any issue before doing this? Or was this purely maintenance?
Old 01-05-2019, 08:31 PM
The tractor was running and driving just fine. I was merely doing some long over due maintenance as the hyd oil was looking poorly , just dirty , no water inclusion.
I drained the bottom plug , removed rear diff cover , drained. Changed filter , refilled with Hy Tran.
Then upon restart ..... no love
Old 01-05-2019, 08:34 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Did you prefill the filter , (airlock maybe)
Oz
