Old 01-25-2019, 09:12 PM
jes6388 jes6388 is offline
Default New here Cub Cadet 1650
I have a 1650 that is currently a non runner. I would like to fix it up, get it running, and use it. How hard are parts to come by? My grandpa was tinkering with it but lost interest. I have found most of the parts he took off of it. I believe it was pretty complete when he got it.
Old 01-25-2019, 10:00 PM
sawdustdad's Avatar
Welcome to OCC! The 1650 is a beast of a machine.
Parts are basically everywhere. Most wear parts are available new (bearings, clutch, springs, switches, etc.) What is not available new may be found as NOS/new old stock or used. Check the forum sponsors or google cub cadet parts suppliers. ccspecialties.org and ihccw.com are a couple parts suppliers I use.
Go to the technical section of the forum and download the owner/operator manual, the chassis service manual and the Kohler engine manual.
Post up some pictures.
Old 01-26-2019, 02:56 AM
Welcome aboard!!
If you have to get into the engine big time it will quickly become pricey.
Figure on at least $250-$350and up for an overhaul and that's doing it yourself.
I am just finishing up an engine for my 1650 and already the bill exceeds $500 w/parts and machine shop work.
How far apart is this machine??
Post up some pictures if you can.
Old 01-26-2019, 05:55 AM
Welcome to OCC..........
I have a 1450 (1650's little sister). It is one of my favorite models. Nice tractor. As stated above, parts are no problem.
Old 01-27-2019, 12:53 AM
I'll get some pictures posted hopefully tomorrow (Sunday). Unfortunately it's in pretty sad shape. I'm wondering if it's even worth fixing. It's definitely going to take some work but I think it would be fun. I do have a question. what does the 2050670 in the first part of the serial number mean? In the little bit of research I've done it was built in Feb. of 78.
Old 01-27-2019, 12:57 AM
Welcome aboard!!
Thanks for the heads up! My grandpa had taken all the tin off and that's about it. The engine did turn over but that was a few years ago. My grandpa liked to start projects and then not finish them. He pulled it around behind an old wood shed and left it there. That was 3-4 years ago. I'm sure the weather has done some more damage to it. It's going to take some work. I'll post a couple pictures and maybe get your opinion if it's even worth fixing. Thanks for replying!!!
Old 01-27-2019, 07:17 AM
That is a Model code that IH used.
The "205" means it is a Garden tractor. The "0670" is the actual build model number.
The "U" after the model code stands for USA built.
The numbers after the "U" are the sequential serial number.
Old 01-27-2019, 08:39 AM
The 1650 is a desirable tractor and a little work horse.
Looking fwd. to yer pix's, most are fixable and you learn many things doing just that.
The group here is full of valuable info and helpful,welcome!!
Old 01-27-2019, 09:42 AM
Bamafan Bamafan is offline
Inactive Member
I know it must look like an impossible mission with it being a basket case. But trust me and these guys here if you enjoy tinkering and learning it will be a fun project to put humpty dumpty back together and you will not be disappointed. The 1650 is the big brother to the 1450. I got a 1450 3 years ago that was a basket case, kind of what you are explaining. I had never worked on a small tractor or any tractor for that matter, but I love to tinker and I took on the challenge.
One important suggestion, if you decide to take on this project take LOTS of pictures as you tare it down then use the pictures and manuals in the tec section on this site to put it back together, they will answer most any question you may have. If you get stumped on something ask, these guys will help.
This is the thread I did on my 1450 I brought back to life
https://www.onlycubcadets.net/forum/...ad.php?t=45262
[B]Larry[/B]
Old 01-27-2019, 10:15 PM
Default Pictures
I'm still figuring out this site but here are a couple pictures of the 1650. I do have most of the tin. I'm just missing the side panels.
