Old 03-08-2019, 02:18 PM
SLS327 SLS327 is offline
Default Clutch driving disc spring
On a 126 clutch disc:
Do the spings go on outside of clutch pressure plate or inside?
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 03-08-2019, 03:08 PM
cooperino's Avatar
Funny.. I just posted this in anther thread also..
Everything you want to know about rebuilding your clutch
https://www.onlycubcadets.net/forum/...ad.php?t=54233
Old 03-08-2019, 03:12 PM
Merk Merk is offline
I don't used them. They usually won't let the clutch/driveshaft not come to a complete stop. I will change the coiled pins and the bushing in the 3 pin driver.
Here is a link to clutch rebuild found the technical section:
Project Uncle Dick
Cub Cadet 70
Old 03-08-2019, 03:17 PM
Yea, i have read through that. There is not mention of the clutch disc driving spings i talk about. They go on the three pins on the inside or outside?
Steven
Old 03-08-2019, 03:21 PM
Thanks Merk. Exactly whats going on with my 126! I hate grinding gears. Maybe just one. Whats the purpose of these? Why did ih do this? Must be a reason? Do they go on the inside? Thats where i put mine, but maybe they go on outside?
Steven
Old 03-08-2019, 03:28 PM
I am the one who did the how to.
If you want to use the springs I would put the springs between the 3 pin driver and clutch disc.
The link posted in my post has an IH Cub Cadet 70 that was done without the springs It was done 10 years ago with no problems. This tractor gets used the most.
Project Uncle Dick
Cub Cadet 70
Old 03-08-2019, 03:34 PM
I used three and yes they hold the disc against the clutch plate. The shaft does not stop when clutching.
Steven
This is only a guess....
IH used a different clutch disc material that had steel in it. The springs were there to help the holes from being egg shape.
Project Uncle Dick
Cub Cadet 70
Old 03-08-2019, 05:28 PM
I only use one spring.
Old 03-30-2019, 10:26 PM
I took two off of there today, and it still grinds. Anyone with narrow frame manuals chime in on the number and orientation of springs? Are they even required!
Steven
