Old 04-06-2019, 03:10 PM
twoton twoton is offline
Default Barn Find
In 1997 I built this barn for one of my customers. It's a pole barn with creosote treated hemlock poles, 1 x 12 native pine wall and roof sheathing and an attic truss roof system. The roofing is 18" red cedar perfections and the walls are 16" white cedar extras. The slab is for heavy equipment, 2' steel reinforced concrete at the perimeter and 6" steel reinforced at the body. We used antique granite for the form work to give it that historic look. All work was hand nailed.
Old 04-06-2019, 03:16 PM
I built it shortly after I built this barn on the same property. This one is post and beam construction. I spent 6 weeks cutting and assembling this structure in a series of 5 vertical stations, each assembled lying flat on the first floor deck, one on top of the other. It was kinda funny as the neighbors had no idea what I was doing. And then, in one day, with the help of some friends and a crane, we raised and assembled the entire structure.
Old 04-06-2019, 03:22 PM
Shortly after the work was complete on the pole barn, my customer and now good friend Ed, stuffed his Ford tractor in the back. And there it sat, all this time. Lately, I've been seeing the need for a dedicated mowing tractor so I decided to drop in on Ed and check out his old Ford.
On initial approach, it looks like we have Cat 1??? rear lift, rear PTO and dual hydraulic ports. That's a good start!
Old 04-06-2019, 03:30 PM
Well, this says a lot. Ford 4000 with non louvered tins, I would guess 1968 - '75. Three cylinder diesel. Internal wet disc brakes. Power steering pump mounted reservoir.
Old 04-06-2019, 03:33 PM
One thing that I notice is alot of yellow paint under the blue...
And over the ID tag too!!!
Old 04-06-2019, 03:36 PM
It does have the 3000 front end and steering and I was able to make out what looks like "D1414C" on the model tag.
So, I'm gonna say its a '68 - '75 Ford Special Utility 4000
Old 04-06-2019, 03:39 PM
Drained all the #&*NASTY!#* smelling fuel from the tank and changed the filter. Despite how rusty the tank is my magnet would not pick up any of the brown crud in the old filter.
I checked the Wix site to confirm that the filter #33166 was compatible with the C.A.V. injector pump...
Old 04-06-2019, 03:46 PM
This swing out battery tray is cool!
Unfortunately, despite clean fuel, new filter and plenty of cranking amps... no smoke and no fuel when I cracked the injector fittings.
Old 04-06-2019, 03:47 PM
Time to pull it out and order a manual.
Old 04-06-2019, 05:23 PM
Darrell Darrell is offline
Nice barn find !!
Tags
cav injector pump, ford 4000 su
