Old 09-05-2019, 08:23 PM
Rwgarrison23's Avatar
Rwgarrison23 Rwgarrison23 is offline
Default Air filter for k301 engine.
I ordered a air filter to add on to my list of things I need to get my k301 up to date. Ebay stated k301 among other engines. Did I get sent a wrong filter?
Old 09-05-2019, 08:29 PM
There were "Many" version of the K301. When ordering Kohler Parts, it is wise to order the correct parts for the particular "Spec" number you are working on, so you get the right parts.
Old 09-05-2019, 08:32 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Kohler k301 filter is 6 inches outside diameter and 2 inches thick without the foam.
Plow blade
#2 Cart
QA36 snowthower
Old 09-05-2019, 08:37 PM
Back to the drawing board...
Old 09-05-2019, 09:01 PM
Can you guide me the right direction
Old 09-05-2019, 09:03 PM
you need the 235116-s filter.
Old 09-05-2019, 10:47 PM
Thank you sir.
Old 09-06-2019, 08:45 AM
The Model/Serial Tag has the Model, Serial, and Spec numbers. See attached image. Also go to the TP-2379 Service Manual (located in Tech Library Section) and look at page #1.3 for further engine data.
When ordering parts, it is "wise" to know and have these numbers, BEFORE you order parts.
