Old 12-15-2019, 10:38 PM
wiley.scott wiley.scott is offline
Default 1974 Model 149
How do I disconnect the hydrostatic transmission so I can push this iron horse onto my truck?
1974 Model 149, purchased in 1974 by my grandfather. later inherited by my father, then it was my turn. It now resides with MY son! That's 4 generations ! And the engine has only been rebuilt once.
Old 12-15-2019, 11:51 PM
athomas's Avatar
athomas athomas is offline
On the right side of the trans tunnel there should be a release lever, if its not broken and the valves aren't stuck, lift it to the up position and you will disengage the hydro. Or pull the tunnel cover off, and push the pins down on the 2 release valves on top of the hydro unit. That is if your not sure that all is working with the lever!
Old 12-17-2019, 10:18 PM
Default 1974 Model 149 Trans
Thank you so much for your helpful insight! I'll get to try it out next weekend when my son and I load it in my truck.
Thank you !! Merry Christmas!
Wiley Scott
Old 12-18-2019, 07:36 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Welcome to the forum too!
We'd love pics of your tractor!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
