Hi All,
I have a Cub Cadet model 125 that am working on, first one, and I can`t figure out how to mount the throttle into the dash. I see a couple of bolt holes under the dash, but can't get my hands in there. Thanks for any tips or tricks. |
First, welcome to OCC............
![]() (A) Is the Throttle Cable new ?? (B) Is it OEM ?? (C) Can you snap some picture(s) of this cable and post them here ??
Thanks for the welcome, looking forward to getting this running, my grandfather had one when I was a kid. I bout the tractor as is not running last summer and it sat in my basement. The cable is not new, but I don't know if it is OEM or not. It seems to be long enough to get where it needs to go, I just can't seem to get it in the dash area. I attached a couple pics. Again, thank you.
20200511_112931.jpg 20200511_112828.jpg |
Pull the Knob Handle off, push it through the Dash Opening from the backside, install the mounting bolts, hook up the cable to the Carb, and then re-install the Knob Handle.
if the screws go in from the side ,you need to pull the hydro handle,take the screws out of dash tin, lift dash tin ,remove knob from throttle, bolt it to the dash tower and reassemble ! I've saw holes drilled in side of fiberglass also to get a screw driver in but wouldn't do it to nice fiberglass dash ! the 1x8,9 series bolt down to top of dash , Just did my 125 a couple months ago !
