Old 07-20-2020, 11:42 AM
7532Cub 7532Cub is offline
Default 7532 Stuck Clutch?
I have the hydrostatic transmission. Just got tractor from my father, it's been sitting for a while. He stored the tractor with the clutch depressed. However when try and use the rear pto i have to grind it into gear. Push in the clutch doesn't stop the rear pto, and also doesn't stop the tractor if i am moving forward. I'm not totally sure what the clutch does on a hydrostatic drive tractor, but I think it would allow me to engage the pto smoothly. I disconnected the clutch rod and tried moving it in and out by hand. It seems pretty easy, like I'm not pushing against the pressure plate. If my clutch is stuck, how does one go about freeing it up?
Old 07-21-2020, 07:51 AM
cooperino's Avatar
Im not real familiar with 7532 model. However on any other hydro cub the "clutch" pedal your referring to is a brake pedal. It also is used to bring the hydro control lever back to neutral, and usually can be locked in down position as parking brake. Besides that is serves as a safety feature for ensuring that the tractor can only be started in neutral.
