Old 07-24-2020, 04:49 PM
bdr3949 bdr3949 is offline
Default Cub 122
why does my 122 internatioal cub cadet die when i unhook the Jumper cables. I have had the alternator rebuilt?
Old 07-24-2020, 05:25 PM
Billy-O's Avatar
Billy-O Billy-O is offline
You likely lost power to the coil when you removed the jumpers. Do you even have a battery in that tractor? A good one?
Plow blade
#2 Cart
QA36 snowthower
Old 07-24-2020, 06:18 PM
the battery that is in there is dead.
Old 07-24-2020, 07:10 PM
mortten mortten is offline
That would be why.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 07-24-2020, 09:54 PM
Originally Posted by mortten View Post
That would be why.
Completely agree. It requires electric power from the battery to run. If it was a magneto, it would work but it's not.
Old 07-24-2020, 10:45 PM
thank you, I thought the alternator would generate enough voltage to keep it running
Old 07-25-2020, 08:04 AM
ironman's Avatar
ironman ironman is offline
The 122 does not have an alternator, it has a generator. They are apples and oranges as far as electricity goes.
They both require a voltage regulator, but the generator equipped 122 has an external voltage regulator which uses voltage from the battery to energize it.
With a completely dead battery (or no battery), once you remove the jumper cables, the voltage regulator de-energizes and the voltage produced by the generator does not reach the rest of the system to give ignition to the engine.
Hope that makes sense.
