Old 10-27-2020, 09:44 PM
Workinprogress Workinprogress is offline
Default 1811 steering column shaft
Have a friend working on his 1811. He noticed something on the shaft.
Anyone seen this before?
File Type: jpg DDE7E7FC-B65D-488E-AC1D-A6780E55E8C2.jpg (32.3 KB, 74 views)
1512 with CADloader 507, CADdigger 508 and 3 pt
1711 with KT17
782 with KT17 and 3 pt
104
Old 10-28-2020, 08:56 AM
Not knowing what you are referring to, I can only assume the blue color of the shaft that is caused by the induction hardening process of the worm end of the shaft.
Or if the stub worm shaft is butt welded to the steering column extension.
either of which is of no concern as the shaft does not spin, just turned manually, and very slow.
