Old 04-18-2021, 02:11 PM
Steveshow Steveshow is offline
Default No spark when cranking 128
I was going over the old 128 getting her ready to cut grass and she wouldn't start. I checked for spark and zero. I dove in and found the point block where the wire from the coil connects burnt up pretty bad. I had put new points in last spring when I used the tractor for the first time after inheriting it from my late uncle and ran it without issues. I believe the coil is not original and due to the damage to points, is not internally resisted (not marked either way) . In an effort to make a quick fix, i flipped the points insulator block over (less damage) and reinstalled the wire from the coil. It is not making a contact to ground now as best i can tell visually. I set the points at .020 gap. I also installed an external resistor that i had in the wire from the ignition switch (which goes to the positive terminal on the coil. I am now getting 13 volts at the coil and points. Still no spark at the plug when cranking so i checked the coil with an ohmeter and it was open. I checked another used coil i had as well as the coil off my running super c. Both had 5 ohms. I installed the used coil and the coil off the super c and neither will give spark at the plug. I ohmed the old plug wire and it reads 4 ohms. I tried a new plug wire from a set i bought for my pickup project as well. Still nothing. I ohmed this new wire and it read 1000 ohms. (???) i tried the old and new plug when checking for spark. I cant figure why the points dont spark when i open and close them manually. Still shorted out from the melted block i suppose. guess i will start throwing parts at it next week; new internally resisted coil, new points and new plug wire. Any suggestions?
Old 04-18-2021, 04:15 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Refer to the following link for checking the coil....
https://www.onlycubcadets.net/forum/showthread.php?t=11
The coil should be to spec on continuity and also be the correct replacement part. Isn't the super C tractor a 6 volt system?
Also, check for continuity from negative wire removed from coil to ground with the points open. There shouldn't be any. With points closed, should read low resistance.
I don't think there is resistor in the plug wire, but others will chime in. Usually no/low resistance on the plug wire.
Finally, replace the points anyway.... If it is burnt, it is likely done. Do replace the condenser while you are at it.
Plow blade
#2 Cart
QA36 snowthower
Old 04-19-2021, 08:14 AM
Thanks Billy-O for the guidance. I have swapped a few points and troubleshot ignition gremlins a few times over the years. This is the first time I came up scratching my head. BTW, the Super C was originally 6 volts but has been converted to 12v. I forgot to include that.
Old 04-19-2021, 08:18 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Is there power to the coil when the key is in the "crank" position?
You may have answered this but I'm not sure: If you manually open and close the points when the key is in the ON position do you get spark?
Is the condenser shorted/leaky (resistive)?
Just some ideas.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 04-20-2021, 12:12 AM
Just some ideas.
There was power to the points when cranking.
I was not getting spark at the points with key on and manually opening and closing them.
Condensor is good.
I happened to remember that there was still a coil on an old parts tractor I had. (CC 73) so I took it off and checked it. (It ohmed out at 35 ohms) i figured i might as well try it. Guess what? SPARK!!! I also robbed the insulator off the ild points in the 73 while i was at it and swapped it out later. I have a new coil on the way, since I was out of “spares”! I have no idea why it will not work with the coil off the Super C, though, as I reinstalled it and it started right up!
Old 04-20-2021, 07:09 AM
Power at the points but no spark.....
Dirty or damaged points. Drag a piece of 220 grit though them a few times, and recheck after resetting the gap. For best results, static time the engine.
Old 04-22-2021, 01:03 PM
Carpetbagger Carpetbagger is offline
Default One more check
Just a thought... Be sure the condensor is getting a good ground by being sure the connection is shiny and tight, (maybe even using a jump wire to insure a proper ground.) Happened to me once. Good luck. Carpetbagger
