Old 10-20-2021, 04:58 PM
Wayne Wayne is offline
Default 108 coil wiring
Putting my dead 108 back together enough to prove the engine is good, but I took it apart 3 years ago so memory has faded a bit, diagrams don't give the detail I need and I don't read schematics.
I have one wire from the condensor to the coil that was never taken off, so that one is fine, but I have 2 wires looking for a home. One comes from the harness where the 2 starter wires emerge on the right side of the tractor, and the other comes from the points.
Do these both go to the non-condensor side of the coil? I am guessing so but I don't like guessing in electrical matters.
Cub Cadet 2166
Old 10-20-2021, 05:42 PM
The Points & Condenser go to the Negative ( - ) side of the Ignition Coil. A single Black Wire goes to the Positive ( + ) side of the coil. This under the assumption that the wiring is original OEM, and no cobbling or modifications.
Old 10-20-2021, 06:09 PM
That makes sense. Thanks
Cub Cadet 2166
