I was getting ready to change the engine oil in my new to me 882. The oil filter that’s on it now (NAPA 1064) is bigger than the one I got (Kubota HH150-32430). According to the parts lookup this is the correct filter. Is it not?
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]() ![]() |
I would trust the Cub Cadet site with Kubota HH150-32430 way before an Auto Parts site with a alleged cross reference.
Well the NAPA filter doesn't come up as a cross for the Kubota filter. The HH150-32430 crosses to a Wix 51365 or a 51365XP so the NAPA number would be 1365
I run Wix 51064 (Napa 1064) in all of my diesel Cubs. If you do a filter look up on the Wix site it shows the 51064 for them.
If you look on the Cub site it calls for a KB-70000-15241. That filter crosses to a 51064. I believe either filter will work fine.
Kubota has superseded the 70000-15241 to HH150-32430 so the 1064 that you had was correct and the Kubota filter is also correct.
HH150-32430 crosses to a WIX 51365 NAPA 1365 70000-15241 crosses to a WIX 51064 NAPA 1064
Thanks for the help guys, it’s on. And good to know what was on there was also correct.
![]() I opted for the newer Kubota recommended HH150 filter, mostly due to space constraints. Obviously, there is slightly more capacity in the original sized filter, but the bigger filter comes very close to the water pump/alt belt, and the oil pressure switch. The smaller filter matches the diameter of the boss perfectly, and is more than adequate for the engine. Like has been stated, either is correct.
![]() 582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
I had no idea so many filters would fit the D600. I've been running a Wix 51334.
