Old 04-24-2022, 10:12 AM
Marko141's Avatar
Marko141 Marko141 is offline
Default 1450 rear end leak
Pulled the 1450 out of storage and it had a leak from the tube on the bottom. Doesn’t appear to be loose, what is the fix? New tube, seal, bushing? Rather know before I take it apart. Photos wouldn’t upload.
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 04-24-2022, 10:30 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Are you sure??? Very common problems are relief valve leaks and cork gasket. They are above the tube and it could mislead your analysis.
Plow blade
#2 Cart
QA36 snowthower
Old 04-24-2022, 10:41 AM
Clean the area well w/some solvent.
When dry, douse the area completely with baby powder and wait.
The leak will leave a trail in the powder leading you right to the leak.
And your Cub will not only thank you but smell good as well!
Old 04-24-2022, 11:09 AM
dodge trucker dodge trucker is offline
I scrapped a perfectly good rear like that, brand new relined disc brakes, all new seals etc /because I was tired of tripping on it and I offered it here in the classifieds for free even and had no bites.
Old 04-24-2022, 11:41 AM
Billy-O's Avatar
That sucks..... If I llve near you I'd be over in a minute!
Plow blade
#2 Cart
QA36 snowthower
Old 04-24-2022, 12:05 PM
Yup, I second that.
Old 04-24-2022, 01:04 PM
Marko141's Avatar
I will have to clean it some more but after what I whipped off I don’t see any runs coming from above, again I wish it was easier to upload the photos to show you.
Old 04-24-2022, 01:09 PM
Marko141's Avatar
https://www.onlycubcadets.net/forum/...1&d=1650820121
File Type: jpg 8B179D46-1DBA-47B0-8F0F-5EF89BF6AE33.jpg (17.8 KB, 95 views)
Old 04-24-2022, 01:52 PM
IF...........you have a bad Suction Tube (rusted), you can check with Patton or Houtz (our sponsors) at the tabs above, or internet (ie: eBay) for a good used one. It is available new from Cub Cadet, being Part Number #927-3008.
Old 04-24-2022, 05:13 PM
Marko141's Avatar
Thanks for the info, I’ll let you all know how it goes.
