Old 04-30-2022, 10:07 PM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
Default 1806 issues
I had some time this morning so I spent it checking out the 1806 I picked up. It has two major issues, one moreso than the other. The left cylinder has no compression and the clutch, although it works, has something not right about it. I'm hoping the lack of compression is, fingers crossed, just a stuck valve, I'm just not sure how I want to attack it.
Is a stuck valve from sitting too long common with these Magnums? Easy to free up or a major problem? Any and all suggestions welcome.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 04-30-2022, 10:14 PM
CubDieselFan's Avatar
Best thing to do is send it to Tennessee. I would like to have one of these.
Just messing with you. I have never had one apart but Mr George will along with some good words of wisdom.
Old 05-01-2022, 08:50 AM
You can pull the breather covers off to see if the valves are moving. I had a M20 with a stuck valve and was able to free it from there.
https://cdn.datamanager.arinet.com/i...d1e83f3/Medium
Old 05-01-2022, 11:23 AM
Radioguy41's Avatar
Good to know, thanks.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 05-01-2022, 06:21 PM
Radioguy41's Avatar
I determined the piston was moving so I shined a superbright LED beam down the spark plug hole and saw the exhaust valve was not moving. I gently inserted a wideblade screwdriver in the hole and with the blade between the valve and the head I twisted the blade gently putting pressure on the valve. I heard the valve spring back so I checked with the light and it had seated. I ran a compression test and now had compression on both sides. I replaced the spark plugs and started it up. Runs smooth now.
Next issue, the driveshaft and clutch.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 05-01-2022, 06:57 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Thumbs up
Hopefully with regular use, this issue will not return. A tight guide, or weak spring can cause this. Glad it's working well again.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 05-01-2022, 07:48 PM
Normally the opposed twins don't have sticky valves as they are horizontal valves
But one that has set unused for a spell, can stick.
I'd not loose sleep worrying that it will stick again.
Old 05-01-2022, 07:55 PM
That's excellent. A person doesn't get too many fixes like that.
Glad it's running for you.
Ken
Old 05-06-2022, 04:01 PM
Radioguy41's Avatar
Hmmm, I think I found the clutch problem. You don't think the bolts instead of pins, the bent plate, the broken discs, the wornout pivot pin, and the off-center throwout bearing might have anything to do with it?
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 05-06-2022, 04:54 PM
1711Cub's Avatar
Unhappy
That's quite the mess.
