Thank you to all you for the advice on checking the battery. Reinstalled today after having it check, it seems to start a lot easier.
Once I had the tractor started, I noticed I have no throttle?? The linkage is moving at governor but no response. Any info on this would be much appreciated. Cheers, Eric |
Hey Eric, I’ve got a 129 and i’ve had a similar issue in the past. There is a metal clamp that goes over the throttle cable under the carburetor and if it slips you won’t have any throttle. Is it missing or is that not the issue?
Is the governor spring being stretched at all?? If so then maybe governor arm has slipped on the shaft. To readjust, loosen the bolt that squeezes it to the shaft then hold governor arm to full throttle position then rotate shaft of governor same direction and tighten bolt. Hope this helps.
