Old 10-08-2022, 05:18 AM
beancent beancent is offline
Default Looking at a Magnum 18
Considering a Magnum 18 for may 782 that had a rod failure. Is the engine a direct swap in. And is there a difference in wiring up to my stock harness. When inspecting a possible engine for replacement, what should I be looking at to make sure I've got a good engine to swap in.
Old 10-08-2022, 06:12 AM
The M-18 is a Plug & Play swap for the KT-17, EXCEPT for a small wiring change. There are two different avenues to pursue on the wiring, and I have done both. It makes a difference in the version of 782's wiring harness. Either way, I have the diagrams and the procedures for both versions.
As far as general motor conditions, the obvious things to look for, ie: does it burn oil, does it leak oil, etc.
Old 10-08-2022, 02:57 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Another somewhat common flaw with the Magnums was the governor gear and it's pin. They are a stouter engine as compared to the KT17, even though they are quite similiar.
Be aware that the horizontal shaft M15 used in the 1541 is the exact same engine except for the carburetor.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 10-08-2022, 05:02 PM
The guy selling this Magnum says it does not smoke or use oil.
Old 10-09-2022, 02:02 PM
Default Out with the KT17 in with the magnum 18
Does anyone have any wiring diagram alteration that they could send me, for swapping the magnum 18 in place of the old KT17
Old 10-09-2022, 02:04 PM
It matters which version of 782 you have NOT the KT-17.
What is your Chassis Serial Number ??
Old 10-09-2022, 02:36 PM
My 782 in not here at the house. I will have to drive over to the shop to check that out.
Old 10-09-2022, 05:03 PM
My serial number is 20505944665171. Wire colors in the starter and pto harness are white, black and brown. the engine harness wire colors are white, red and red/white
Old 10-09-2022, 05:28 PM
Not a good serial number. I am guessing it is 2050594U665171.
Check to see if I am right.
Old 10-09-2022, 05:56 PM
Ok I will have to check it tomarrow
