Old 11-14-2022, 02:21 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
Default IH Cub Cadet 127 rear axle won’t move.
I have a Cub Cadet 127 with snow plow and PTO that I picked up for free a couple months back. I found out that the engine is stuck, so I’m gonna eventually put a different engine in it. However, the rear axle doesn’t turn no matter what, the brake is released, I can’t tell if the parking brake is broken or what (I played with it’s positioning a lot), and it was sitting outside for almost 20 years. I also put it in different gears and still nothing. Any ideas on why this might be?
Old 11-14-2022, 05:43 PM
Soooo... when you jack it up and turn the wheels they do not move?
Up to 534 and counting...
Old 11-14-2022, 08:06 PM
LAWN BOY's Avatar
Default Nope
No, they still don’t move even when I have the tractor jacked up.
Old 11-14-2022, 08:13 PM
That's what I was a thinking. Probably time to isolate what is actually
stuck. I would start with disconnecting the driveline so you know if
it is the engine or the rear end that is not turning. Not had my eyes on
a 127 but is there a release for the hydro valves and is it engaged?
So it rolls. I think you were on the right the track with a stuck brake but
it sound like you sorted that out. Jack it up as was mentioned.
Ken
Old 11-14-2022, 09:12 PM
Are you moving one wheel or both? Try moving one. I believed there is no internal brake in a 127.
Old 11-15-2022, 07:09 AM
Shoes rusted to the discs?
Old 11-15-2022, 07:43 AM
Have you pulled the rear cover to see if:
#1, anything appears broken?
#2 it is a ball of rust, full of water?
#3,most likely if it has disc brakes, the pads are rusted to the rotors as mentioned.
Old 11-15-2022, 07:50 AM
Another question: you say you "put it in different gears"
do you have a manual transmission or a hydrostatic drive?
it makes a difference,---- a hydro don't have gears and a clutch, per say.
Much like a car/truck, either manual shift or automatic
Old 11-15-2022, 08:00 AM
LAWN BOY's Avatar
Default So it could be the engine?
From what I understand from West Valley G’s comment it could be the engine?? The engine is stuck and doesn’t turn per say, would that prevent the rear axle from turning? I just started getting into these tractors a couple months back so I do not have all the knowledge yet.
Old 11-15-2022, 08:03 AM
LAWN BOY's Avatar
Default Rear cover
Ol’ George, It is a hydrostatic, I know now I said that wrong, my bad. Are you talking about the cover one would remove to change the fluid back there?
